Vehicle ECU noise influencing Analog output from DAQ
I'm struggling for noise problem and needs your advice.
One ECU generates ground noise and this is connected the A power supply.
The DAQ system is connected the B power supply.
DAQ generate analog outputs for sensor simulation.
Due to the ground noise, the analog output signals are waving with the noise.
Eventually, all sensor data is waving.
A power and B power grounds are common connected.(shorted)
How can I solve this? Need your fantastic experience and advice.
Thanks in advance.
Best Regards,
Message 1 of 1
(1,937 Views)
