Viewing DAQmx buffer data during acquisition
I am new to DAQmx and I have a question: I am current using reference triggering to start my data acquisition and I know that this function uses a circular buffer scheme.  Is there any way to poll the samples in the buffer while it is being continuously updated before the trigger is detected?
I would appreciate any suggestions and offer my thanks in advance.
CK
(3,951 Views)
Hi CK,
There is one thing that I can think of that would allow us to view the buffers before a reference trigger occurs.  We could perform a continuous analog acquisition with a reference trigger.  I have included a link from ni.com that gives several example programs that show how to implement this.
NI-DAQmx Continuous Analog Input with Both Start and Reference (Stop) Triggers
Give this a look and let us know if this is what you are looking for or if you have any further questions.
Best Regards,
Jeff Tipps
(3,928 Views)
hi,
i have the same problem: i must interrupt the acquisition at some value of data. what i do??? Please, help me. is very urgent
(3,675 Views)
Hey,
Check out these two documents online, Doc1 and Doc2. You would still need to modify then to fit your application.
Good Luck
-lab
(3,649 Views)
