Vista version of NI-435x 2.5.2
Is it possible to use the NI-435x 2.5.2 Instrument Driver with Vista 32bit and Labview 8.6?
(3,296 Views)
Good afternoon rwlocke,
I'm sure you've already viewed the NI-435x 2.5.2 driver online support page which says Windows 2000/XP, with no mention of Vista.   My experience with this type of question is that it has not tested it throughly enough to say, otherwise it would make mention.   That being said, you may be hard pressed to get an NI contact to say it will work.   You may however find another user here who runs it.   Are you considering moving to the Vista platform from something else that works?   In this situation I move only if I have battle-hardened support, or I set up a separate development platform(workstation), and test the @#$% out of it.   If going Vista is critical, self-testing may be your best bet to getting a timely resolution.   Sorry I cannot be of more help!
Zach
(3,287 Views)
It is true that because we do not specifically list support for Windows Vista, it is something that we have not tested and therefore cannot suggest to you to use. I have filed a product suggestion which is directly submitted to R&D requesting support for Vista in future releases of this driver. Have a great day!
Margaret Barrett
Digital Multimeters and LCR Meters
(3,273 Views)
Thanks to both of you for your help!
(3,257 Views)
