Voltage Measurement Across Externally Excited Thermistor
Well if the HVAC Chiller uses the Rs485 , it's quite easy to listen to the protocol without disturbing 🙂  just capture the temp readings that are requested. Less risc than clamp on the existing temp sensor. However I would still just clamp on another thermistor to the water outlet... that's the only clean solution.
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 11
(1,397 Views)
