Voltage control to control flow in MFC through USB6009
Hi People!!
Hope its going great!
Well I am learner in LabVIEW and been studying and researching about automating my simple situation... :smileyhappy:
My setup is really simple:
What I have is 2 Mass Flow Controllers from Bürkert Flow Control (Model - 8710). And they can be interfaced and controlled via simple Analog Inputs.
AlsoI have, NI USB6009 DAQ which has 2 analog outputs, which solve my purpose..
What I want to do, is to simply control the analog outputs into the MFC's simultaneously through two potentiometers (for instance on the front panel) to control the flow rate through MFC's.. The range in which I want to control the voltage is 0-5V..
Can somebody share a sample VI for reference in this regard just to get me started?? All I have reached upto is this VI which I am attaching!
I sincerely look forward to your support!
Thanks in advance!! :smileyhappy:
Regards
Pramit
(4,944 Views)
Hi Dennis! Yea it is me only.. 🙂 I was a bit confused as to which discussion forum is the most appropriate for my question... Well thanks for your reply!! Regards Pramit
(4,903 Views)
