Voltage divider scaling factor and unit
Hello Community,
I'm using a PCIe 6353 DAQmx card to measure Voltages.
Because of the limitation of the input volts I'm using a voltage divider to scale the input volts down to +-10V.
Now I want to safe the data with the correct scaling factor.
If I'm using the custom scale for the "Create Channel (AI-Voltage)" with the proper scaling factor and write "Volts" as string to the "Scaled Unit" Diadem is unable to detect the unit as volt.
Is there a possibility to just add a scaling factor without changing the unit?
Kind Regards
Message 1 of 1
(3,898 Views)
