02-20-2007 01:36 PM
02-21-2007 10:40 AM
03-15-2007 01:51 PM
Thanks for the suggestion. The example helped me learn more about Labview. My next question...
I would like to create a VI that simulates the following cascading if statment:
if voltage from analog input = X,
initiate sound1.wav
if voltage from analog input =X again within specified time frame,
intitate wave sound2.wave
intitate wave sound3.wave
I would like this to continue 50 times. Any suggestions on how to make this work in LABVIEW 7.1?
Thank in advance,
Kurt
03-15-2007 02:31 PM
03-15-2007 02:39 PM
Kenn,
So instead of using the time elapsed function, the flat sequence would take care of the timing issue? Another question, wouldnt i need 50 case structures inside of a flat sqeuence since I may play all 50 sounds in a given loop iteration? Do the case structured have to be placed inside of eachother or just oriented somewhere inside the flate sequence frame?
Kurt
03-15-2007 03:06 PM
03-15-2007 03:13 PM
03-16-2007 01:53 PM
