Voltage range for PXIe-6363
Question regarding voltage range for the PXIe-6363 DAQ. The data sheet shows the voltage range of +- 10V....I assume, in software, I can regulate this range to be used only 0-10V?
(3,205 Views)
No. You have the 7 fixed ranges in hardware and you cannot change them. When you specify a min and max in software, the driver will pick the best actual range to use. In other words, even if you specify a min of 0 and a max of 10, the actual range used will be +/-10.
(3,203 Views)
Ok, thankyou.
(3,199 Views)
