WFM_Op does not return when iterating indefinitely?
I'm using the WFM_Op function with a DAQPad 6020E with the WFMsingleBufRegenerate.C that is provided with NI-DAQ. If I change the number of iterations to zero (i.e., indefinite iterations), it never proceeds to the next instruction.
I'd ideally like to be able to have it repeatedly output a waveform in the background, but so far I've been unable to do it.
(2,602 Views)
I've been using successfully WFM_Load and WFM_Group_Control functions with NI-6711 Analog Output channels, based on WFMsingleBufAsync.c NI-DAQ example to repeatedly output a waveform in the background. I think it might be worthy to give a try.
Silvius
Silvius Iancu
(2,602 Views)
Hello;
If you input a zero as the iterations parameter, the NI-DAQ driver will probably hang your computer.
The way to keep generating the same waveform on a output channel, is to set up a continuous Analog Output operation, and pass the same array of point (the array that will determine the waveform), and keep running the Analog Output task in a loop.
That will make the same array of point to be generated over and over again, which will accomplish what you need.
Hope this helps.
Filipe A.
(2,602 Views)
