WLS-9163 Ground Terminal Connection
The manual for the WLS-9163 says on page 9 that the ground terminal of the device should not be attached to the common terminal of the C Series I/O module.
Will problems arise if I connect the common terminal of the I/O module to the ground terminal of the WLS-9163?
http://www.ni.com/pdf/manuals/372488c.pdf
Thanks in advance for the help.
(3,352 Views)
The modules are usually isolated depending on the module so that is why you would not want to tie the ground of the module to the chassis.
Carl W.
Applications Engineering
(3,304 Views)
