Want to know to use counter pulse for sampling of analog input/output - PCI-6111 with DAQmx 9.4
I want to use counter pulse which uses external source into PFI8 for analog input/output. I am using PCI-6111 and DAQmx 9.4.
With Traditional DAQ 7.4.4, the following code could what I want.
	iStatus = Select_Signal (m_deviceNumber, ND_RTSI_0, ND_GPCTR0_OUTPUT, ND_LOW_TO_HIGH);
	iStatus = Select_Signal (m_deviceNumber, ND_IN_SCAN_START, ND_RTSI_0, ND_LOW_TO_HIGH);
	iStatus = GPCTR_Control(m_deviceNumber, ND_COUNTER_0, ND_RESET);
	iStatus = GPCTR_Set_Application (m_deviceNumber, ND_COUNTER_0, ND_PULSE_TRAIN_GNR);
	iStatus = GPCTR_Change_Parameter (m_deviceNumber, ND_COUNTER_0, ND_SOURCE, ND_PFI_8);
	iStatus = GPCTR_Change_Parameter(m_deviceNumber, ND_COUNTER_0, ND_COUNT_1, ulLOWcount);
	iStatus = GPCTR_Change_Parameter(m_deviceNumber, ND_COUNTER_0, ND_COUNT_2, ulHIGHcount);
	iStatus = GPCTR_Control(m_deviceNumber, ND_COUNTER_0, ND_PREPARE);
	iStatus = Timeout_Config (m_deviceNumber, timeout);
	iStatus = WFM_Group_Control (m_deviceNumber, 1, 0);
	iStatus = AO_VWrite (m_deviceNumber, ANALOG_OUTPUT_CHAN, 0.0);
	iStatus = Select_Signal (m_deviceNumber, ND_OUT_UPDATE, ND_RTSI_0, ND_LOW_TO_HIGH);
	iStatus = WFM_Load (m_deviceNumber, 1, chanVect, dataArray, iNumPoints, 1, 0);
	iStatus = WFM_ClockRate (m_deviceNumber, 1, 0, 0, 1, 1);
	iStatus = WFM_Group_Control (m_deviceNumber, 1, 1);
iStatus = DAQ_Start (m_deviceNumber, ANALOG_INPUT_CHAN, range, collectionBuffer, iNumDataPoints, 0, 1);
iStatus = GPCTR_Control(m_deviceNumber, ND_COUNTER_0, ND_ARM);
	iStatus = DAQ_Check (m_deviceNumber, &daqStopped, &retrieved);
	while (daqStopped !=1 && iStatus ==0)
		Sleep(100);
iStatus = GPCTR_Control(m_deviceNumber, ND_COUNTER_0, ND_DISARM);
	iStatus = DAQ_VScale (m_deviceNumber, ANALOG_INPUT_CHAN, range, externalGain, 0, iNumDataPoints, collectionBuffer, voltArray);
		//Start another buffer data collection if needed
		iStatus = DAQ_Clear (m_deviceNumber);
 With DAQmx, I changed the code as follows:
	iStatus = DAQmxConnectTerms("/Dev1/Ctr0InternalOutput", "/Dev1/RTSI0", DAQmx_Val_DoNotInvertPolarity);
	iStatus = DAQmxCreateTask("", &inTaskHandle);
	iStatus = DAQmxCreateTask("", &outTaskHandle);
	iStatus = DAQmxCreateTask("", &counterTaskHandle);
	iStatus = DAQmxCreateCOPulseChanTicks(
		counterTaskHandle,
		"Dev1/ctr0",
		"/Dev1/PFI8",
		DAQmx_Val_Low,
		0,
		iLOWcount,
		iHIGHcount);
	iStatus = DAQmxCreateAOVoltageChan(
		inTaskHandle,
		"/Dev1/ao0",
		-10.0,
		10.0,
		DAQmx_Val_Volts, NULL);
	// write initial value of 0 to the output so we have the same starting state
	iStatus = DAQmxWriteAnalogScalarF64(
		outTaskHandle,
		false,
		timeout,
		0.0,
		NULL
	iStatus = DAQmxCfgSampClkTiming(
		outTaskHandle,
		"/Dev1/RTSI0",
		1, /* arbitrary with external clock */
		DAQmx_Val_Rising,
		DAQmx_Val_ContSamps,
		1000 /* automatically determined by sample interval */
	iStatus = DAQmxWriteBinaryI16(
		outTaskHandle,
		iNumPoints,
		true,			/* Start automatically */
		timeout,
		DAQmx_Val_GroupByChannel,
		dataArray,
		NULL,
		NULL);
	iStatus = DAQmxCreateAIVoltageChan(
		inTaskHandle,
		"Dev1/ai0",
		DAQmx_Val_Cfg_Default,
		- cdRangeMaximums[range],
		inTaskHandle,		// task handle
		"/Dev1/RTSI0",		// clock source
		1.0,	// sampling frequency (ignored for external clock)
		DAQmx_Val_Rising,	// sampling timing
		DAQmx_Val_FiniteSamps,	// finite samples
		iNumDataPoints);	// number of samples
	iStatus = DAQmxStartTask(inTaskHandle);
	// Start Clock
	iStatus = DAQmxStartTask(counterTaskHandle);
	iStatus = DAQmxReadBinaryI16(
		iNumDataPoints,		// number of samples
		timeout,		// timeout
		true,			// Fill Mode
		buffer1,		// output buffer
		iNumDataPoints,		// array size
		&actualDataPoints,	// actual data points
		NULL			// reserved in future
 I am expecting RTSI0 is connected to counter pulse output and it is used for sampling. However, DAQmxWriteBinaryI16 and DAQmxReadBinaryI16 don't work with timeout error (-200284).
It seems that RTSI0 does not any clock pulses. Does anyone let me know what I am wrong?
Neppie
Message 1 of 1
(2,965 Views)
