Was zu tun beim / What to do when: Error -88705 occurred at Self-Test (NI-DAQmx 9.3.5 / Windows 7 32bit)
System configuration:
Windows 7 32bit
NI-DAQmx 9.3.5
 what is the solution?
(3,878 Views)
the system takes a lot of time during booting...
(3,877 Views)
the board is PCIe 6251
(3,876 Views)
what does Windows Device Manager look like?
(3,869 Views)
everything looks fine in the Device Manager (attached is a print screen of it)
(3,843 Views)
Youre device may have entered a weird state due to any number of reasons (power outage, program crash, etc)
Try resetting the device in MAX.
If that doesn't work, reboot the PC.
If that doesn't work, shutdown the PC, move the card to another PCIe slot if possible, or take it out and put it back in making sure it is seated properly.
If that doesn't work, reinstall your DAQmx driver.
If that doesn't work, send it in for an RMA.
(3,824 Views)
