Watchdog on analog output port
Hi everyone,
I have a NI DAQ USB-6343. I use the internal watchdog to reset some digital output ports when something happens with my software or PC.
Question:
Is it also possible to reset an analog output port with the watchdog ??  (Task.Watchdog.ResetTimer)
(953 Views)
Not supported on X Series devices, only on certain cDAQ.
See Table 1 in How to Use and Implement the Watchdog Timer With NI-DAQmx
https://tmesystems.net/
(932 Views)
Thank you, pitty. I think i have to use a relay controlled by the watchdog then.
(903 Views)
