Waveform File Size
Hello, I am acquiring data from 3 PCI-6052E cards, at a rate of 10kHz.
I am using the low-level waveform file VIs (open / write / close) to write the waveforms I acquire to a file, and these files are massive (about 3 MB per second of logging). Is there a way to cut this down, and still have a valid timestamp to plot against?
Any help would be GREATLY appreciated! Thanks!
(3,506 Views)
Hi again tritone
By default, waveforms are DBL data format ( see Application note 154). One way to cut size down and keep using waveform data type is:
1- scale waveform for 16 bits.
2 extract Y ( dbl)
3 conver Y to I16
3 insert into waveform
The new waveform will be I16 data (1/4 of DBL)and you will keep all waveform attibutes.
It should decrease file size
Hope this helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,506 Views)
Thanks for your reply .. this seems like what I want to do, however I am not sure what you mean by "scale waveform for 16 bits". Could you explain? Thanks!
(3,506 Views)
Hi Tritone
Your DAQ card is 16 bits converter, so you have to scale you V range to 16 bits to keep relationship.
See attached example
Hope it helps. you can achieve a data reductio to 1/4 of original, without loosing data and keeping timestamp.
Alipio
(3,507 Views)
That's great, I got it working .. my files are now about 1/3 the size they were .. thanks!
(3,506 Views)
Could you send this in V6.1 ?
(3,495 Views)
Here is the VI saved in LV 6.1.
(3,485 Views)
