What NIDaq legacy driver can be used with Win7 OS ?
Several clients are using legacy 6023e boards.  they desire to stay with those NI boards.
What NIDaq legacy driver can be used with win 7 OS (64bit) & LV 2010 ?
Have tried both 7.44 and 7.5  - NI give both errors saying they support vista, etc.   - not win7.
thanks
(3,292 Views)
There is no traditional driver support for win 7 64-bit. Unless the applications were originally created prior to LabVIEW 7, they should have used DAQmx. Conversion is the only option if they want to use them with a 64-bit os.
(3,281 Views)
Hi raddad,
The NI DAQ 7.5 beta will work in Win 7 32 bits only, it will not work in Win 7 64 bits, you can use this link as reference. I tested it in my computer (I have Win 7 64 bits) and I got the same error.
steve.bm
AE | NI
(3,271 Views)
