What are the limits of the PCI-6023E's overvoltage protection?
What are the limits of the PCI-6023E's overvoltage protection to its analog inputs using RSE? How much voltage can it handle before it is damaged? How many times can it handle a 100V input before it is damaged?
(2,875 Views)
According to the specifications (page 3), the max voltage is much less than 100V !
(2,863 Views)
stoico,
JB is correct.  The maximum working voltage (from channel to ground) is +-11V. The overvoltage protection is as follows:
                                 Signal Powered                               On Powered Off
AI <0..15>                  ±42                                                     ±35
AI SENSE                   ±40                                                    ±25
I would also not recommend running this at 100V.
(2,845 Views)
