What do I need to link to gpib-32.obj in MinGW?
I want to link to ..\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc\gpib-32.obj using MinGW. I used the new GPIB header and I made a import library (lib<name>.a) using pexports ("pexports gpib-32.dll > gpib-32.dll"). But when I try to compile, I get these errors:
..: undefined reference to `ThreadIberr@0'
..: undefined reference to `ThreadIbsta@0'
..: undefined reference to `ibeos@8'
..: undefined reference to `ibeot@8'
..: undefined reference to `ibtmo@8'
..: undefined reference to `ibsad@8'
..: undefined reference to `ibpad@8'
..: undefined reference to `ibonl@8'
..: undefined reference to `ibwrt@12'
..: undefined reference to `ibrd@12'
..: undefined reference to `ThreadIbcntl@0'
..: undefined reference to `ibdev@24'
..: undefined reference to `ibclr@4'
..: undefined reference to `ibfindA@4'
collect2: ld returned 1 exit status
I think this is similar to http://forums.ni.com/t5/Multifunction-DAQ/Howto-use-NIDAQmx-with-mingw-gcc-3-4-2/m-p/294361, where the exports of nidaq32.dll (NI-DAQmx library) need to be first merged with the nicaiu.dll exports in order to create libnidaqmx.a. This can then be compiled in MinGW.
(4,596 Views)
what language are you compiling this in?
(4,530 Views)
It's C++ compiled with g++. The tooling & commands that I use to make the lib are:
pexports gpib-32.dll > gpib-32.defs
dlltool -k -d gpib-32.defs -l libgpib.a GPIB.DLL
The link above doesn't work. Use this link instead:
(4,524 Views)
