What is DAQmxSetTrigAttribute?
In the example code Download - CPlusPlus_Retriggerable_AI_Using_Retriggerable_Counter.zip what is the function DAQmxSetTrigAttribute(counterTask, DAQmx_StartTrig_Retriggerable, TRUE);?
What does it do?
What are the definitions for each of the parameters?
Kevin
(3,587 Views)
Hi Kevin,
The attribute ids that are valid for the DAQmxSetTriggAttribute() are in the included NIDAQmx.h file.  They can be found under the heading
"//********** Trigger Attributes **********"
Similarly, the attribute ids for the DAQmxSetBufferAttribute can be found under the heading
"//********** Buffer Attributes **********"
These attributes are each defined in the NIDAQmx.h file.  The parameters given to the functions include the task, the attribute, and the value to assign the attribute.
I hope this helps!
Justin M.
(3,565 Views)
