What is a AC ground ?
I recently configured a PCI 6221 for Differential Input and fed the input with the signal from a digital panel meter's retransmission output ( +/- 10V level ) The DPM was powered by the mains and did not have the third earth pin - just the phase and neutral terminals.
Thus  the DC side of the DPM electronics was powered by a step down transformer / diode bridge / 7812 regulator. As the DC ground was not linked to the mains earth , the voltage output could be termed as "floating source " ?
But when I connected this output to the differential input, I was surprised to  find it working normally even without any  bias resistors. Somebody  said  this  was working because of the  AC ground on account of the step down transformer.
I am not sure I followed - can some one clarify this point a bit more ??
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,007 Views)
Do you know the output impedance of the DPM? Wondering if it is quite low and that's why differential is working.
I do not agree with the logic regarding AC gound and the transformer.
For kicks, you could ohm out the DPM outputs, each one individually with respect to AC ground.
(3,003 Views)
