What is a NI p/n for 2.5mm screwlocks installed on the 68-pin connector?
What is a NI p/n for 2.5mm screwlocks are installed on the 68-pin DAQ Card connector?
(2,497 Views)
Greetings,
It appears that the KnowledgeBase linked below contains the information you desire:
What Are the Specifications and Dimensions of the Jacksocket Screws Used on 68-Pin Board-Mount Conne...
If this is not the p/n you need, you may want to consider presenting this question to one of NI's technical support engineers. They should be able to obtain this information for you. You can create a support request from the following location:
Request Support
Spencer S.
(2,497 Views)
