What is a recommended replacement for the PCI-6723 and PCI-6225?
We have received letter from NI about NI boards PCI-6723 and PCI-6225 end of production at the end of year 2023.
Questions.
1) What is a recommended replacement for the PCI-6723?
2) What is a recommended replacement for the PCI-6225?
(947 Views)
Most of the time, there is no direct replacement for the obsoleted modules. It depends on your requirement.
Are you looking for spare hardware for the existing system? Are you looking for hardware with the same spec? What is your budget? The more information you provide, the better we can recommend.
NI-DAQmx will still support the new hardware thus the effort on software modification is minimum.
https://tmesystems.net/
(942 Views)
