The Test Panel outputs correctly and some of the example functions output correctly (such as WFMsingleBufSync). The AOonePoint example doesn't output anything either. I am measuring the output from the TBX-68 terminal block using an oscilloscope and I have also tried using a multimeter for the single point functions and I just measure a voltage spike and then 0V.
Is it only possible to fill the buffer with the WFM_DATA_U8, WFM_DATA_I16, WFM_DATA_F64, WFM_DATA_U32 ulTypes? What do I do if, for instance, I want to have a 2V sine wave, or a different period?
