What is the channel set up for measuring axial thrust probes using the eZ Tomas software and an IOtech data logger
Is there anybody out there who can give guidance on configuring a axial thrust probe in eZTomas. I have tried all configurations that I can think of but the guage still just shows a full scale even when I connect a 9.5v battery.
(5,868 Views)
Please see the attached document.  I hope this will be helpful.
Very Best,
Dave McFate
David J. McFate, CVA Cat. III
Staff Systems Engineer
Sound & Vibration Group
dave.mcfate@ni.com
(5,855 Views)
Thanks Dave,
I have already set it up, I used the static setting instead of the general one. Will this make a differance. I can't open the document attached but I did see the images.
(5,825 Views)
Hello Phil,
I cannot see the document either, I am unsure why this is acting so strange.  If you would like to send me an email at dave.mcfate@ni.com I can sent you the attachement directly.
The only real difference between STATIC channels and GENERAL channels is the raw data saved in eZ-TOMAS.  STATIC channels save only the averaged time domain "data point" for each record.  A GENERAL channel will save all of the sampled data points from the signal, allowing you to view the "real" signal in replay.  Static are usually used for temperature data, or other slowly changing signals where an averaged datapoint is more than  sufficient for analysis.
I am glad that this information helped,
Dave
dave.mcfate@ni.com
(5,822 Views)
Accepted by topic author Phil D
Hello all,
I have re-saved the document as a PDF file and uploaded it here for reference. Download this and hopefully you will be able to see the splendid document Dave has created.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
(5,807 Views)
That is first class, thank you very much.
Phil
(5,802 Views)
Thank you so much Larry!
Very Best,
Dave
dave.mcfate@ni.com
(5,796 Views)
