What is the current versio of Traditional NI-DAQ, 7.4.1 or 7.4.2?
What is the current version of the Traditional NI-DAQ, 7.4.1 or 7.4.2? Where is the version 7.4.2? Is there some problems with drivers 7.4.2?
jm
(3,225 Views)
Hi jm-
The most recent version of Traditional NI-DAQ available for download is 7.4.1.  Traditional NI-DAQ 7.4.2 is available on the LabVIEW 8.20 (and any associated LabVIEW 8.20 toolkits) Driver CD.  The only reason to upgrade to Traditional NI-DAQ 7.4.2 is if you are using LabVIEW 8.20; otherwise you should use Traditional NI-DAQ 7.4.1.
Hopefully this helps-
Tom W
(3,212 Views)
