What is the last (Traditional) NI-DAQ version?
The site says it is 7.44, yet I have run into version 7.50. Is the latter a BETA or a RELEASE and why is it not the "official" NI-DAQ version? Is there a difference between NI-DAQs 7.44 and 7.50, or are they same so differences are to be found in the accompanying utilities...?
I'd be happy to know how stable are my Traditional NI-DAQ base applications (have experienced some odd behaviour).
Thanks in advance,
(3,160 Views)
See this.
(3,155 Views)
Dennis,
Thank you. I will remove it immediately, however it will remove other parts like (DMM, FGEN, etc.) Will all of them be automatically reinstalled with the NI-DAQ 7.44 afterwards? Current Ni-DAQmx is 9.23, is it affected by the TDAQ 7.50 removal? What would do to restore the systme with NI-DAQmx 9.23 and NI-DAQ 7.44?
Thanks in advance,
(3,151 Views)
Depending on your application, you may not need to re-install NI-DMM and the other drivers that uninstall with it. If the uninstall removes the other drivers and you want to reinstall them all at once, you can run the device driver CD or find the download here. Traditional DAQ 7.5 will not install these other drivers.
Also, the newest version of NI-DAQmx is 9.3 if you're planning on reinstalling it.
Jake H | Product Manager
(3,126 Views)
