What is the maximum current of an analogue input ?
Hello..
I have got this NI 6040E and want to know what should be the maximum current that I  must not supply to the analogue input .
some help would be appreciated
(2,905 Views)
Hi Bharath,
The 6040E Specifications let us know that the card has a 100 GΩ in parallel with 100 pF for the analog input channels, therefore the current input will be nominal. Just make sure to stay within the +/- 10V range, and you should be OK.
David L.
Systems Engineering
(2,888 Views)
