What is the maxium output cabability (Out rate) of cDAQ NI9263?
I am using cDAQ 9263 in my project for analog output; But i face some problem while using this DAQ in 'Back plane Multiplexing'!
Can you please help on this.
Yogesh Redemptor
(3,239 Views)
Hi Proffesional,
    The maximum output rate for the NI 9263 is 100,000 Samples per second. The outputs of this module are updated simultaneously so you can update all 4 channels at this speed. This information can be found on the NI 9263 product page linked below.
NI 9263
I'm not sure what you mean by "Back plane Multiplexing". Can you provide any more details or a specific error code you are getting?
Hope this helps
Nathan
Nathan
NI Chief Hardware Engineer
(3,226 Views)
