07-08-2013 09:51 AM
07-09-2013 09:09 PM
Hi DHagan
If you want to add properties to the waveform in LabVIEW 2012 there is an example that might be useful for you is located on this path:
C:\Program Files (x86)\National Instruments\LabVIEW 2012\examples\Waveform\Operations.llb\Create Waveform example.vi
But the easiest way to separate an array of waveform is to use the index waveform array VI.
Regards
Esteban R.
