What is the recommended NIDAQ Version to use with the DAQCard1200?
I've upgraded my PC with NI-DAQ 6.9.3 and now the DAQCard1200 does not work properly. What is the latest version that supports use of the DAQCard 1200?
(3,019 Views)
The latest version of NI-DAQ suitable for your application can be found at at the DAQ Driver Version page. Most likely you will be using version 6.9.3.
If you are having problems with your device then you should start off with the troubleshooting steps that can be obtained from the hardware installation/configuration troubleshooter.
If problems persist, post back so that we may be able to help out. Best of luck.
Jared A
(3,011 Views)
