What is the time between samples for an NI 9205?
I'm using an NI 9205 in a cDAQ-9172 chassis.  What is the time between channel readings?  Is it the 4us conversion time listed in the specifications so that at a sample rate of 100hz, every 0.01 seconds the channels are read at 4us apart which takes 28us?  Is this constant and independent of the sample rate?  Is this adustable?
Thanks!
Jim
(2,991 Views)
I needed the answer quickly, so I called in.  The convert clock is set to 14us for slower acquisition speeds (1/250k + 10us).
It changes to 4us (1/250k) for faster data aquisition speeds.
(2,987 Views)
