What size screws are used in the nylon spacers on the CB-68LPR
I have a CB-68LPR connector block that came with 0.5" long nylon spacers/standoffs for mounting.  What type of screw will fit in these spacers?
(3,237 Views)
Have I stumped you?
(3,205 Views)
Measure the ID of the spacer. Use a screw that has a smaller diameter. Screws have standard diameters - either metric (ie. units in mm) or English (ie. units in fractions of an inch).
If that's too technical, take the spacer to a hardware store. Keep trying different screws until you find one that fits.
(3,201 Views)
Hi Hinar,
Welcome to the NI Forums!  The CB-68LPR uses 4-40 x 3/16" screws to fit in the standoffs.  Thanks for posting and have a great afternoon!
-John
John Passiak
(3,185 Views)
