What type of terminal connectors are available for the SH68-68-EP cable?
  I plan on using my data acquisition system (M-Series 6259) for generating and acquiring Ultrasound signals.  These will be low level signals from an amplifier with power rails of 0-3.3V.  I am wondering what type of terminal connectors are available for the SH68-68-EP Noise Rejecting, Shielded Cable (as well as other cable using the same 68 pin connection).
-Brant
(3,062 Views)
Hello Brant,
Glad to hear you are using the M-series 6259 for your ultrasound applications. First, let me clarify that the M-series devices will need the SHC68-68-EP Noise Rejecting cable, not the SH68-68-EP. The difference is that the SHC type cable incorporates the D-type 68 pin connector on one end used by M-series devices.
We have several types of terminal connectors available for various applications. These can be organized as follows:
BNC
SCB
SCC
While the BNC and SCB connector blocks provide you with the basic screw terminal and BNC connections, the SCC connector blocks allow you to incorporate signal conditioning into your application.
Since the 6259 has two connectors available, you will be able to use up to two of the same connector blocks, or two of different types. I hope this provides some insight and helps you get your foot in the door for your application.
Chris Behnke
Sr. RF Engineer
High Frequency Measurements
(3,034 Views)
