When configuring my cDAQ 9188 Ethernet chassis, error 88705 was encountered
I'm configuring my cDAQ-9188 Ethernet chassis and I have encountered an error: Error-88705, when configuring the board using NI MAX. On my pc running on Windows 8.1 and using having 2 network cards, I have installed LabVIEW 2014 and than NI-DAQmx9.9 which was upgraded to 14.5. I tried to communicate with the board using both DHCP and static IP but this error still persisted. Furthermore, I've re-installed the NI-DAQmx a couple of time since one of the suggestions was that it might be a software problem. However, the TCP connection is established correctly in both cases (when using static IP or not) since when I'm able to configure the board through NI Network Browser and it works perfectly. Still, through LabVIEW I cannot access the board via the DAQ assist. Moreover, the NI-loader settings were changed according to  http://digital.ni.com/public.nsf/allkb/0819391CA91B3EB38625731D00024649?OpenDocument  and the fire was switched off. Kindly find attached relevant screenshots. Do you have any suggestions, please?
Thanks in advance.
Best Regards
Joseph
(8,297 Views)
There is a thread where another person had a similar issue to your problem. There are some steps that you could try listed in there. Could you see if these steps work for you?
This is the thread http://forums.ni.com/t5/Multifunction-DAQ/Error-88705-with-a-USB-6366-DAQ/td-p/1861203.
(8,280 Views)
Good morning Inachosa,
Thanks for your reply, unfortunately, I do not have access to the referred thread. Thanks
(8,262 Views)
I am sorry it seems that I pasted with a misspelling. Here it is
(8,248 Views)
Thanks, but still I did not solve the issue. I have implemented the improvements show in the table below without any success. As shown in the screenshot the error is still encounter
Improvement
Link
Result
2 port configuration
http://digital.ni.com/public.nsf/allkb/AC929F0881D9178A862578B000586491
Error 88705
NI Device Loader
Running /Updated but error 88705 still unsolved
NI mDNS Resp Ser
NI Configuration Manager Service
http://forums.ni.com/t5/Multifunction-DAQ/NI-USB6211-Error-88705/m-p/2371998/highlight/true#M76206
Resetting MAX Database
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
Error 88705
Firewall off
Error 88705
(8,217 Views)
Accepted by topic author Joseph92
Hello Joseph92,
I just found a very similar case, where the error was resolved by repairing NI DAQmx and NI LabVIEW. You can do this by going to the Control Panel/Uninstall or change a program/Software of National Instruments, then choose all DAQmx and NI LAbVIEW options and finally click on repair.
It seems that the problem is with a configuration of web services of LabVIEW. And repairing the software fix this problem.
Greetings and let me know if this was useful
Guillermo O,
Guillermo Oviedo
R&D Software Engineer
CLA | CTD
(7,674 Views)
