03-26-2009 03:35 PM
I am using a USB 6008 with the first analog input set to differential and five others set to reference single ended.
Do I need to use the ground connection when making an RSE measurement?
I ask because according to the connection diagram shown by the express DAQ assistant, the differential input is using pins 2 and 3 while one of the RSE inputs is using pins 3 and 4. If pin 3 is not at the same potential as ground for the RSE input I expect there would be problems. Why would this pin be shared in such a way?
Also, is there a place inside LabVIEW/MAX other than the DAQ assistant where I can view connection diagrams (preferably one with pin numbers)?
Dave
03-26-2009 06:25 PM - edited 03-26-2009 06:25 PM
