When will XP operating system support be available?
Only need support for NIDAQ and VB Component Works (Measurement Studio).
(2,759 Views)
Windows XP is already supported by the latestet versions of NI software. Check the following link for seeing what versions are already supported.
http://digital.ni.com/express.nsf/bycode/winxp?OpenDocument〈=&node=
Hope it helps.
Aguila
(2,759 Views)
I totally agree with Aguila. The official version of the NI-DAQ driver that can be used with Windows XP is NI-DAQ 6.9.2
You can download this driver from our website:
Current Versions: NI-DAQ
I would recommend to take a look at the readme.htm file. This file will tell you whether or not the hardware that you have can be used with this version of the driver. Keep up with the good work!
(2,759 Views)
