Where can I find Analog Input VI's?
Thanks a lot for the person who'll answer me.
Barto
(3,238 Views)
If you have LabVIEW installed on your system,
Menu>>Help>>Find Examples>>Hardware input output>>DAQmx>>Analog Measurements folder will contain the Analog Input VI's for DAQmx
Menu>>Help>>Find Examples>>Hardware input output>>Traditional DAQ>> Analog input Folder will contain Traditional DAQ example VI's
Or you can search and locate them on www.ni.com  in 'Support' page
Hope this helps,
Regards
Dev
(3,235 Views)
In fact, the problem was that the vi's were not on my computer...
I had to install DAQ Traditional.
Problem solved!
Thanks Dev.
Barto
(3,231 Views)
