Where is setup.exe in NIDAQ1800f1.zip ?
I am trying to install the drivers for a nimdaq usb-6211.
I downloaded the NIDAQ1800f1.zip  file and unzipped it.
The instructions said to run the setup.exe file, but there is no setup.exe or anything similar in that zip.
How do I install the drivers?  (And also the .net tools, if there is anything to be installed there)  Note i am not using labview.
(3,103 Views)
Hey, it should be in the main folder. I just downloaded it and it is there:
(3,066 Views)
Thanks.  it turns out that the file was not unzipping completely.  there was a silent error rhat left much of the filestill zipped.  A colleague had the sane issue on a different computer and using a different tool until we realized.  We switched to 7zip and got it.
thanks
(3,059 Views)
Oh I see. Well, I'm glad that you could figure that out!
Adrian
(3,054 Views)
