Where is the docmentation for programming a NI 6221 board without the NI software/drivers
Our problem is that when we configure the NI-6221 card for single-ended
channels, we lose data when reading more than 12 channels at a sample
rate of 5 KHz. We do not have this problem when reading all available
channels and the channels are set to differential. Though there are only
8 channels available when in this mode, and that may mean we are
not near the 12 limit. We sometimes have a reading failure when the
number of channels drops to 11 or 10.
We use:
1.  a Real Time OS (RTOS) that is not supported by NI (InTime by Tenasys)
2.  NI-6221 PCI data acquisition cards
3.  Visual Studio 6 (can upgrade to VS 2003)
4.  Intel PCs with MS-Windows operating as a process/thread under the RTOS
     (the real-time program runs independently of any Windows application)
5.  our own software for programming the NI-6221
We presently:
1.  have a sparse document listing some of the registers and their functions
2.  RTOS software that accesses the NI-6221 PCI card, reads digitized data,
     and outputs signals.
We need:
1.  documentation on programming the NI-6221 without the APIs or drivers
     (including initialization, DMA transfers, etc.),
     as they would be useless in the RTOS.
(3,145 Views)
You are looking for the Driver Development Kit. You will want to post your questions to the DDK Board.
(3,137 Views)
