Whether MyDaq can be used to interface the eeg cable with labview????
I wanted to measure eeg signal and hence I use eeg electrodes but inorder to process it in labview...how can i interface it with labview...whether i can use Mydaq or any other boards????
(2,637 Views)
to measure eeg signals you need some differential ampiliers (better ones with active guard) .
another important feature of these amplifiers is, that they make shure that you don't electrify yourself 😄
(even in case of one failure)  and no, usual DAQ equipment with usual powersupply doesn't have these isolation classes.
Greetings from Germany
Henrik
LV since v3.1
(2,614 Views)
