Which DAQ Events are supported by PCI-6733
I need to synchronize AO output and an external card at an event rate
of 4kHz. Since the external card has a trigger input, one solution
would be to program a GPCTR and use it to trigger the analog output
and the external device, but I would prefer an interrupt-based
solution since it gives me more control. It is not clear to me which
of the various DAQ eventgs are supported by me card, the PCI-6733,
except for the fact that DAQ Event#9 is out.
Perhaps there is another interrupt-based solution besides DAQ Events?
Many Thanks,
Geoff Lewen
(2,570 Views)
Hi Geoff
You can see which DAQ Events are supported by your board by going to:
Start -> Programs -> National Instruments -> NI-DAQ -> Traditional NI-DAQ Function Reference Help
If you search for �DAQEvent Messages� in the index, it will bring up a table of DAQEvent Messages. In the far right hand column, you can see which devices support the messages. Since you have a PCI-6733, your device supports messages 0, 1, and 2.
This link may also help:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/7b95597f3c6138f8862567eb006c9638
Hope this helps.
Russell G.
Applications Engineering
(2,570 Views)
