Which devices support AO-FuncGen
I have tried searching Google and the forums, and the in-program help, but I can't find the answer.
What devices support the AO-FuncGen output type?
(3,480 Views)
Bauer_CT,
Is there a certain product line you’re looking to use? Knowing your application or broader goal might help answer your question better. Otherwise, there is a property node (attached below) which you can connect to a simulated device but doing that with per device would be a cumbersome process.
http://zone.ni.com/reference/en-XX/help/370471AE-01/mxcprop/attr2fd3/
Ali S.
Ali S.
Applications Engineering
(3,439 Views)
