Which hardware will allow internal sample clock for DigitalWaveform hardware generation ?.
I want to use a DAQ device to generate a DigitalWaveform (for a Digital Output task), with hardware timing (using an internal sample clock with customizable frequency).
With my USB-6000 I get an exception when trying to do something like
DOtask->Timing->ConfigureSampleClock(System::String::Empty, clockRate,
NationalInstruments::DAQmx::SampleClockActiveEdge::Rising,
NationalInstruments::DAQmx::SampleQuantityMode::ContinuousSamples,
std::abs(samplesLimit));
It complains about an unsupported NationalInstruments::DAQmx::SampleTimingType
But I don't even know if it is possible with any DAQ device.
Where in the tech specs of each device could I find the fact that it would be supported or not ?
Message 1 of 1
(2,199 Views)
