04-10-2008 08:55 AM
Hi Chris and Laurent,
Please find herewith a pdf-file with my last results concerning the oscillation "problem".
You were right in the sense that the oscillations are probably an artefact of the filter. It is not a simple low pass filter at all!
However, I am still disappointed because if I am measuring a stepwise signal, I have to remove about 35 sampled values before and 35 sample values after each step transition to obtain a result that corresponds to the real signal applied at the input of the ADC!!! Therefore, the effective sampling frequency is in fact decreased by a factor of about 65...
I will contact NI directly to have more information about this filter...
I thank you again for your help!
Frédéric
04-10-2008 12:42 PM
