Why is my differential AI channel floating to 10 volts?
I am using a USB-6229 DAQ with LabVIEW 7.1 and the lastest DAQmx drivers.  I am trying to measure a thermocouple reading and getting bad results.  When checking the analog channel (wired differentially), MAX reports that the differential voltage across the channel is 10.6 volts.  Is this a hardware problem, or is there something I can do to alleviate it?
Jon
(3,070 Views)
Just to be clear, as I did not mention it before: I have both terminals shorted to each other with a wire, and yet the DAQ still reads 10 volts.  If I ground either terminal to the chassis or AI GND, the voltage immediately drops to zero.  However, after a few seconds, measured voltage increases to 10.6V again.
(3,062 Views)
Another excellent NI support req.:
(for anyone interested)
Jon
(3,052 Views)
Hi Jon,
Were you able to solve the problem by adding in a bias resistor? I assume this is something you have tried based on your reference to the Developer Zone tutorial. I just want to make sure that things are working properly for you now. Thanks!
Daniel S.
(3,026 Views)
Yup, all working and thank you for the followup.  That was one of those field wiring techniques we've never quite needed before due to chassis connections (read: dumb luck).  But that was the exact tutorial I needed.]
-Jon
(3,013 Views)
