Why my PCI card 6731 (4 analog output) does not pass the ressource test in MAX with NIDAQ 6.9.3 ?
In french : Carte All-In-One PC Intel Pentium 3 avec bus passif équipé de 7 slots PCI, 5 ISA et 2 PCIMG.
Le problème ne se pose pas avec une autre machine AMD Athlon 1,2 Ghz.
J' ai essayé la version 6.9.3 de NI-DAQ mais le problème persiste
(2,527 Views)
Hello;
The best way to go about that is to uninstall the NI-DAQ completely and remove your board from your machine.
Then, reboot the machine and reinstall NI-DAQ only, reboot the machine again and put the board back in.
If you see the same problem, try the board on diffrent slots and ultimately, on a different machine.
Hope this helps.
Filipe A.
(2,527 Views)
Thank you for your help.
I found the problem : it was due to the Power Supply of my PC. For PCI-6731 Card you must have a 3.3V Supply in your computer.
(2,527 Views)
