Will a PCI-1428 interface with a DAQ - PCI - 6534?
I have a Camera Link camera with a PCI 1428 card and was wondering if it will work with a DAQ PCI-6534. Thanks!
(2,518 Views)
Both 1428 and 6534 have a Real Time Signal Interface (RTSI) connectors on them. Using this bus you can route signals (timing, triggering, etc.) between boards directly instead of going through the PCI bus. This will simplify your coding and improve reliability and performance of your application. You'll need a RTSI ribbon cable to connect two (or more) boards together.
Hope this helps!
Yusuf C.
Applications Engineering
(2,518 Views)
Thank-you!
(2,518 Views)
