Wiring NI-9237, NI-9949, and strain gauges
Hi everyone,
I have two wired strain gauges that I want to connect to an NI-9237 through an NI-9949. I also have an NI-9945. Unfortunately, I haven’t been able to collect any data so far, and I think I may be wiring it incorrectly.
Can anyone help me with the wiring on this and how to connect them to each other?
(102 Views)
Please share your current wiring diagram so that we can help reviewing it.
https://tmesystems.net/
(80 Views)
I’m using 2-wire strain gauges connected through an NI-9949 into an NI-9237 module.
Currently, I have:
EX+ (Pin 6) and RS+ (Pin 4) tied together to one pad on the gauge.
AI+ (Pin 2) connected to the other pad.
I also tried adding a precision 350 Ω completion resistor between AI− (Pin 3) and EX− (Pin 7), and a jumper between RS− (Pin 5) and EX− (Pin 7).
In software (Python via NI-DAQmx and in NI-MAX), I’ve set the bridge type to Quarter-Bridge I, excitation to 2.5 V internal, and the gauge factor to 2.06.
However, the readings stay constant at around ±51,000 µε, which looks like a saturated / open-bridge signal.
Could you please help confirm whether the wiring above is correct for a Quarter-Bridge I configuration using a 2-wire gauge, and if not, what modifications are needed?
(41 Views)
