Wiring plan for Pressure Transducer and Flow Sensor Ni9207
Hi at all,
i m struggling with the wiring of my two sensors to a 9207 Module which is placed on a cDAQ 9136 Device
Setup:
cDAQ 9136
Module Ni 9207
Biotech Flow Sensor:
Pin 1: +5-24 VDC
Pin2: Ground
Pin4: S
Gems Pressure Transducer ( code G, Current mode )
Pin1: +V
Pin2: Return ( 0V )
Pun 3/4: Not connected
Datasheets:
attached below
Issue:
The wiring of the sensors at itself seem pretty clear. I Just don't know how to connect it to the NI 9208. Would be great if someone could provide me some wiring plan.
Many Thanks to you all,
Marco
(2,721 Views)
Hi Marco,
I see that there is no activity around this question. Did you manage to solve this problem? Just by reading through your question I am a little bit confused about 9208 statement, was it supposed to be 9207?
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,617 Views)
