WriteAnalogF64 delay response
Hi, I use the fujnction WriteAnalogF64 to write 100 samples in an analog port for my SCB-68 (NI) card, I have an multimeter to read the output for this port, it works great (no delay) under the TEST window of NIDAQ-MX task creation, in my code I call the created task, and every .120 sec the function WriteAnalogF64 is executed, but has a big delay..... i dont know what could procuce it....
thanks.
(3,184 Views)
Hello Mxal,
What are you using to time WriteAnalogF64? Do you get this same delay when you don't use a task from the Measurement and Automation Explorer and you create the task programmatically? Have a great day!
Sincerely,
Marni S.
(3,172 Views)
