Writing a given number of digital signals?
I want to construct a program for my NI USB 6009 (using Visual Studios C++, 6.0) for programming a program which:
1. Receive a trigger signal, a TTL-signal. This on one digital channel, is "Dev1/ctr0" ok?
2. When received one trigger signal starts to write a number of digital signals on another digital output for example "Dev1/port0/line7".
3. After writting the signals receive an analog value on for example "Dev1/ai0".
The problem is that I cannot control the number of "peaks" or "1" that I write with my write function (DAQmxWriteDigitalU8).
I want to be able to write for example 80 "peaks" or "1". I have given "samples to be written"=aver_num=80, but I do not see 80 "peaks" or "1" on my oscillioscope. I have tried with different digital chars to write= with the dig_char_writ ={1},with the dig_char_writ ={0,1,0,1,0,1,0,1} but this do not seem to effect the number of "peaks" or "1" that I see on my oscilloscope?
Instead of 100, I see 11 and so on, always much less. It seems random for me how many I see..
I am new in the area and excuse if I have done some fatal errors. I would be glad for some tips help!
This is my program:
___________________________________________________________________________________________________________________
//ADC-program
// Defenitions
#include "stdafx.h"
#include "NIDAQmx.h"
#include <stdio.h>
#include <cstdio>
#include <iostream>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
using namespace std;
int main(void)
    int32       error=0;
    char        errBuff[2048]={'\0'};
    TaskHandle  taskHandle_1=0;
    TaskHandle  taskHandle_2=0;
    TaskHandle  taskHandle_3=0;
    uInt32                 data=0;
    int32                   aver_num=80;
    const uInt8         dig_char_writ ={1};
    int32                   skrivna=0;
    DAQmxErrChk (DAQmxCreateTask("DICount",&taskHandle_1));
    DAQmxErrChk (DAQmxCreateTask("DOWrite",&taskHandle_2));
    DAQmxErrChk (DAQmxCreateTask("AIRead",&taskHandle_3));
    DAQmxErrChk (DAQmxCreateCICountEdgesChan(taskHandle_1,"Dev1/ctr0","",DAQmx_Val_Falling,0,DAQmx_Val_CountUp));
    DAQmxErrChk (DAQmxCreateDOChan(taskHandle_2,"Dev1/port0/line7","",DAQmx_Val_ChanPerLine));
    DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle_3,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
    DAQmxErrChk (DAQmxStartTask(taskHandle_1));
    for( data; data<1; data++ )
    DAQmxErrChk (DAQmxReadCounterScalarU32(taskHandle_1,0,&data,NULL));
    DAQmxStopTask(taskHandle_1); //Then stop this task
    DAQmxClearTask(taskHandle_1);
    cout << "Trigger signals from laser received: " << data << endl;
    DAQmxErrChk (DAQmxStartTask(taskHandle_2));
    DAQmxErrChk (DAQmxWriteDigitalU8(taskHandle_2,aver_num, 1, 10.0, DAQmx_Val_GroupByChannel,&dig_char_writ,&skrivna,NULL));
    DAQmxStopTask(taskHandle_2); //Then stop this task
    DAQmxClearTask(taskHandle_2);
    cout << "Number of digital samples written: " << skrivna << endl;
Error:
    puts("");
    if( DAQmxFailed(error) )
    DAQmxGetExtendedErrorInfo(errBuff,2048);
    //if( taskHandle_1!=0 )
    //DAQmxStopTask(taskHandle_1);
    //DAQmxClearTask(taskHandle_1);
    //if( taskHandle_2!=0 )
    //DAQmxStopTask(taskHandle_2);
    //DAQmxClearTask(taskHandle_2);
    if( taskHandle_3!=0 )
    DAQmxStopTask(taskHandle_3);
    DAQmxClearTask(taskHandle_3);
        printf("DAQmx Error: %s\n",errBuff);
    printf("End of program, press Enter key to quit\n");
    getchar();
    return 0;
I would like to know why I do not see 80 "peaks" or "1"on my oscilloscope and how I can solve this? I know that there can be other ways to write this program, which I may not have realized, if there is any one who see/know an obviouse much better way I am glad for tips and help!
Kind Regards, Hanna
Message 1 of 1
(3,946 Views)
